Multimedia over Coax Alliance (MoCA)
Ven Fév 07 2014, 03:42
The Multimedia over Coax Alliance (MoCA®) is the universal standard for home entertainment networking. MoCA is the only home entertainment networking standard in use by all three pay TV segments---cable, satellite and IPTV. The current MoCA specification can support multiple streams of HD video, deliver up to 175 Mbps net throughputs and offer an unparalleled user experience via parameterized quality of service (PQoS).
MoCA has more than 118 certified products and more than 54 members worldwide representing the home entertainment network value chain including service providers, OEMs, consumer electronics companies and chip vendors.
•Operates with IPTV, CATV and DBS
•Easy to install -- no new wires required
•No interference or crosstalk from existing networks
•No additional service calls or truck rolls
•Works with any wireless network
•PQoS for managed bandwidth
complémentarité/alternative:
utilité: éviter de recabler, utiliser le cablage existant sans ajouter de nouveaux cable (réduction des coûts)
hybrid broadcast/broadband
Solution multimedia par cable coaxial
IP Ethernet bridge coax
genre brancher sa STB horizon/netbox/humax via MoCa adaptateur à un autre convertisseur MoCaTV branché au cable téléréseau directement à la prise TV DVB-C/S/IPTV
MoCA est en phase de test en Suisse/Allemagne selon la carte géographique du déploiement.
shéma explicatif
http://www.mocalliance.org/files/13-450-459-WH-MoCA_V5.pdf?PHPSESSID=d582abf9f8909a1642fc01c16ff37f39
référence:
http://www.mocalliance.org/index.php
http://en.wikipedia.org/wiki/Multimedia_over_Coax_Alliance
Horizon est compatible MoCA, le tout est de trouver ces adaptateurs MoCa convertisseur DVB/IP over Coax
http://www.telecompaper.com/news/liberty-global-unveils-horizon-hybrid-stb-at-ibc--825767
shéma explicatif
référence:
- visiteurInvité
Re: Multimedia over Coax Alliance (MoCA)
Dim Fév 09 2014, 05:51
d'un autre point de vue, avec le système MoCA,
cela permettra également à un client du téléreseau câble cuivre coaxial de passer de citycable/cablotel/upc-cablecom à un opérateur IPTV sans changement de cable ce qui est indispensable/bénéfique pour réduire les coûts et les risques
ou
permettre au client de rester avec l'opérateur téléréseau cable coaxial tout en profitant du systeme multimédia/VoD/etc... sans changement de câbles tel horizon/netbox
ou
